Re: H piston installation
Posted by Theman on June 27, 2006 at 09:03:52 from (65.248.77.5):
In Reply to: Re: H piston installation posted by IndianaRed on June 27, 2006 at 06:37:14:
The numbers on the cap and rod go to the camshaft side (right-hand) side of the engine.
Yes, the spring goes on first under the oil ring. Oil it up really well as it can dig into the piston and not compress as it should. Also, make sure the gaps in the two parts are 180° apart from each other.
