Re: Champion Plugs
Posted by NDS on June 27, 2006 at 12:50:11 from (152.163.100.65):
In Reply to: Champion Plugs posted by IndianaMike on June 27, 2006 at 09:46:17:
You may be right but I have run thousands of hours using AC, Autolite and Champion plugs and in my opinion all of them are fine if they are correct heat range, gapped right, tractor is not using excessive oil and carburation is right.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
