Re: super C hydraulic
Posted by Hugh MacKay on June 27, 2006 at 18:24:50 from (209.226.247.139):
In Reply to: Re: super C hydraulic posted by Mike D. on June 27, 2006 at 17:59:11:
Mike: I'm not saying I'm going to have your answer, but our discussion may tweek someone else's brain.
The two hydraulic hoses you replaced supply oil from control valve to fast hitch lift cylinder, right or wrong? Could this be a case of loosing enough oil when changing hoses, you have drained resovoir refilling the system? Do the rockshafts on the touch control work properly? What is the oil level in your resovoir?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
