Re: What would the gap be on a 300?
Posted by Janicholson on June 27, 2006 at 20:30:27 from (134.84.102.134):
In Reply to: What would the gap be on a 300? posted by Levi K on June 27, 2006 at 20:00:19:
The amp meter must get juce with the key off. If not there will be none for thecoil, or accessories. If it is showing discharge, then there are issues. The Gap is .o2o" Good luck,
JimN
