Re: Champion Plugs
Posted by Rob Baird on June 27, 2006 at 20:54:40 from (68.59.175.236):
In Reply to: Champion Plugs posted by IndianaMike on June 27, 2006 at 09:46:17:
HI
I worked in a garage we stocked all 3 plugs
used ac in gm
autolite in ford
champion was chrysler
although sometimeds used autolite in chrysler
Use whatever works best for you
I have run across some things that did like one plug better than another but all are usually good
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
