Re: super C hydraulic
Posted by Brian in Iowa on June 27, 2006 at 21:36:02 from (69.66.212.31):
In Reply to: super C hydraulic posted by Mike D. on June 27, 2006 at 17:14:02:
when refilling,remove the fill cap,start the tractor,speed the engine up alittle,and move your control levers back and forth 10 to 15 times,recheck fluid level.Doing this, the air can escape out the fill hole.When full,your fluid should be 1" below fill hole.It will take a couple times doing this to get all the air out and your fluid level correct.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
