Bearings are usually tighter on shafts than housing. On the counter shaft it may be possible to get the balls out of bearing then get the inside and outside race out if it won't come out since you are replacing anyway. The input shaft assembly will come out with the housing on front after removing the 3/8 dia. 9/16 wrench size bolts. Then shaft and bearings can be removed from housing if not possible in tractor. Drive yoke key has to be removed from front of shaft. New bearings need the ring groves for placing shafts in correct spacing.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
