Throttle problems after carb rebuild ('47 Cub)
Posted by hillbillyOH on June 29, 2006 at 05:42:37 from (134.53.248.149):
I recently rebuilt the carb on our '47 Cub. Everything seems to be working fine, other than the fact that I've lost throttle sensitivity. I'm sure it has to do with the new throttle screw and spring that was installed, but I can't seem to figure out the problem.
Is there a proper way to install these things? Do you set it with the trottle all the way closed? Open?
