Re: Super A-Fuel from sediment bowl-no flow to fil
Posted by BobCD on June 30, 2006 at 06:58:43 from (67.140.16.252):
In Reply to: Super A-Fuel from sediment bowl-no flow to filter posted by BobCD on June 29, 2006 at 17:52:49:
Thanks again for your input, I will change out fuel filter with a gravity drain style. The tractor came with this inline filter, not sure if it's for auto or tractor? I know the lines arent pluged, because its all new hose and tubing. I did take out the screen at the top of the sediment bowl since there is an inlin filter. I do appreciate all your comments.
Bob
