Re: 300 wiring woes (again) with pics
Posted by Dellbertt on June 30, 2006 at 19:07:18 from (204.39.208.243):
In Reply to: 300 wiring woes (again) with pics posted by Levi K on June 30, 2006 at 16:53:36:
1. Will the tractor start with the switch off.
2. Disconnect everything and start over and hook up one by one.
3. Make sure to follow mfg.diagram or get one of Bob M
4. Somewhere you are going to find a wire that is hot (voltage) when it should not be.
