Re: 300 wiring woes (again) with pics
Posted by old on June 30, 2006 at 19:13:23 from (4.245.7.57):
In Reply to: Re: 300 wiring woes (again) with pics posted by Levi K on June 30, 2006 at 16:55:08:
Can't see in the picture how you have the plug wired so I'll just tell you how it should be and also the reason why it maybe getting hot. Its most likely that its getting hot when your chargeing it because you have the #1 and #2 terminals wire backwards and you are keep the excite part of the alternator hot/voltage to it all the time. Now heres how it should be wired and you also need a doide or lite or you will have other problem. The #1 terminal goes to the ignition switch the side that is off when the switch is off. The #2 terminal goes to the big lug on the alternator. Now if its wired that way and you don't have a lite blub or doide in the wire going to the switch you will not be able to turn the engine off because the alternator will back feed the ignition
