1066 fuel system
Posted by Ts on July 01, 2006 at 05:36:47 from (67.9.60.235):
I am having trouble with the fuel system on my 1066 IH. Is the injector pump supplied by a feed pump, or is it gravity fed. If there is a supply pump, where is it located?
The trouble is that it will not idle at low rpm's, if you try to idle down real quick after full, or high rpm's it will just go ahead and die. Thanks..Ts
