Re: Battery Decharging
Posted by Bus Driver on July 01, 2006 at 05:40:58 from (66.44.248.190):
In Reply to: Battery Decharging posted by Tweeter on July 01, 2006 at 05:12:16:
The most sensitive test is to use a dial-type (not digital) voltmeter between the disconnected cable and the empty battery post. I have found battery drain rates of less than 1 volt using this method. Keep the top of the battery clean.
