Re: NOW I DID IT!
Posted by Bus Driver on July 01, 2006 at 05:44:00 from (66.44.248.190):
In Reply to: NOW I DID IT! posted by GMM on June 30, 2006 at 19:52:35:
Always use two wrenches to remove and install these units. The outer nut is the one that is supposed to be turned. The one near the head or block is to be held stationary. This avoids twisting the capillary tube.
