Re: 300 Transmission Noise
Posted by Larry in MO on July 01, 2006 at 07:19:14 from (216.146.244.88):
In Reply to: 300 Transmission Noise posted by Stu Red on July 01, 2006 at 05:56:02:
Stu; Does your tranny make the same noise on both sides of the T/A[high or low]? Never heard of one doing that, but strange things happen. If the noise changes speed when you shift the T/A, then its tran related. If it stays the same speed, then it may be clutch related. Good luck.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
