Re: Rustolium 1 Thinned Milk 0
Posted by CNKS on July 01, 2006 at 11:26:58 from (204.249.178.138):
In Reply to: Rustolium 1 Thinned Milk 0 posted by Tom Windsor on July 01, 2006 at 11:20:57:
What Pale Rider meant in his own sarcastic (or maybe humorous) way was the durability of the paint. With alkyd enamel (Rustoleum) it is best to keep the tractor inside and wax it every 6 months or so. Alkyd enamel will fade badly and eventually chalk -- meaning it gets powdery and eventually comes off. Also each time you wax, you are removing paint. Eventually you can wax it down to the primer, so don't do it too often. Take care of it and it will last. But don't expect it to last as long as the current automotive paints.
