Re: Farmall H Rim Repair
Posted by Tom Windsor on July 01, 2006 at 20:49:12 from (205.188.116.133):
In Reply to: Farmall H Rim Repair posted by Skyhawk Greg on July 01, 2006 at 18:50:49:
Greg. There is usually a lot of rotten metal here that does not weld good. I have done what you suggest and I know the work, labor and aggrivation grinding it down after finishing to make sure tube is not snagged by my welding...there are enough of these rims around to find one. Why don't you look a little first.
The last one that I did was with 1/8 inch sheet steel cut to the approximate size, tacked in place, heated and then hammered to shape and welded it in...wroked out good but a lot of work.
TW
