Re: Battery Decharging
Posted by gene bender on July 02, 2006 at 04:25:51 from (66.43.221.61):
In Reply to: Battery Decharging posted by Tweeter on July 01, 2006 at 05:12:16:
When the switch is off meter should read zero. But when you turn key on it should show a little discharge as the points are likely closed and drawing a little current. Sounds like you just dont have a problem or the battery would run down.
