Re: Light duty IH disks built in 1960s
Posted by Hugh MacKay on July 02, 2006 at 10:06:26 from (209.226.247.189):
In Reply to: Re: Light duty IH disks built in 1960s posted by Mingo on July 02, 2006 at 05:59:21:
Mingo: Actually that may be quite a bit of help. I'm thinking all those old disks with 7/8" square arbor probably used the same bearing. As I recall that 10-A was available with 4, 5, 6 or 7 blades to the gang or in the case of a tandem disk 16, 20, 24 and 28 blade disk. I wasn't too awfully concerned about the bearing. Just curious if they ever used the 7/8" arbor on more than 16 blade disk or 4 blades to the gang. Thank you very much.
The bearing on my disk, two halves are held together and mounted to frame by two 1/2" bolts on 3-1/2" centers. If that is not exactly the same a bit of fabrication will fix that quickly. My thoughts were to find a disk with good bearings ideally 5 or 6 blades to the gang and mount those on my fast hitch disk frame. I would then use the gangs I have as parts supply.
