Re: used or new pistons sleeves
Posted by old on July 02, 2006 at 18:20:49 from (4.244.186.162):
In Reply to: used or new pistons sleeves posted by bshannon on July 02, 2006 at 18:05:10:
In the long run its better to do it right and replace all the sleeves and pistons. Then you know you have a good engine. Useing used sleeves can be a night mare BTDT and lost when I did. I tried to use some used sleeve and found that the engine they camew out of had the block shaved and then I could ever got the head gasket to seal as it should have becauce the one sleeve sat down to low
