Re: Attn: CNKS Need more brake info
Posted by Michael Soldan on July 02, 2006 at 18:25:31 from (24.235.41.226):
In Reply to: Attn: CNKS Need more brake info posted by Bootman on July 02, 2006 at 17:12:49:
Bootman, listen to Harold, you could bust the bearing cage if you mess with it. Use a tiny punch or picking chisel and collapse the seal housing, if you can bend a side of it down and get vise grips on it you can pull it out, some recommend drilling a small hole and screwing a metal screw in , then you can get a hold of the metal screw. I have had luck getting a sharp punch between the seal casing and the tractor housing, once you can do this you can collapse the seal inward and it will then come out very easily. I use the new neoprene seals and you can position them in a different part of the shaft to avoid the groove that has likely been made by the old seal. Remember the bearings are behind that seal casing so be patient and work carefully , it will come out. Good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
