Re: 1947 Farmall A
Posted by Nat 2 on July 04, 2006 at 05:24:56 from (24.93.8.168):
In Reply to: 1947 Farmall A posted by Bill in VT on July 04, 2006 at 04:20:20:
That's an overflow drain, really. Not picking on you specifically here, but it just baffles me how so few people know even the most basic troubleshooting techniques for a simple 4-stroke gasoline engine... Air, fuel, and fire at the right time. Suck, squeeze, bang, blow... They're not that complicated, yet so many people just stand there and scratch their heads, or check useless stuff like oil, coolant, muffler bearings... Air is generally a gimmee. It takes a lot for the air passage to get plugged, and odds are if the tractor ran fine yesterday, the airway ain't blocked. Timing is also usually a gimmee, if you shut the tractor off because you were done using it. All bets are off if the tractor went "BANG!" and suddenly quit, though. You'd have mentioned that in your post, though, RIGHT? (There have been cases where people have failed to mention OBVIOUS physical damage, i.e. a rod sticking through the side of the crankcase...) Fire is the next thing to check. Magneto or distributor? If you pull the coil wire off at the distributor cap, hold it 3/8" from the frame, and have someone crank the tractor over, does a hot blue spark jump the gap? If not, you have no fire. Fuel is the last thing. Carbs get stuck sitting overnight, and like Hugh said, you may need a carb kit. Then again, the gas draining may be a result of you cranking and cranking and cranking and cranking with the choke pulled. That sucks lots of gas into the intake, and it will run out the overflow. Anyway, if it doesn't fire within the first few cranks, cranking on it more ain't gonna make it start. GET OFF the tractor and start troubleshooting.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
