Re: H Compression Loss
Posted by Andy Martin on July 05, 2006 at 12:44:44 from (64.219.39.195):
In Reply to: Re: H Compression Loss posted by IndianaRed on July 05, 2006 at 12:27:14:
Wet with gas and good blue spark don't go together.
Do you have compression bubbles in the radiator?
A coolant leak will not necessarily cause a miss, so you may have two problems.
I'm sure you've backed the rockers off to make sure you don't have a valve leak. Did you grind the valves?
I've had good luck with Bars Leaks when it is not a compression leak.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
