Re: H Gas Tank Removal
Posted by EdRed on July 06, 2006 at 08:07:43 from (148.104.5.2):
In Reply to: H Gas Tank Removal posted by H Gas Tank on July 06, 2006 at 03:59:45:
After you remove the nuts and springs, try to unscrew the studs from the bottom of the gas tank using a small pipe wrench. If, and only if, the studs come loose without excessive force on the pipe wrench, disconnect the fuel line and remove the fuel bowl. You can then slide the tank off the supports to the tractor’s right side. No need to disconnect the steering shaft.
