Re: MagMan...Please Read
Posted by Larry Ed on July 07, 2006 at 08:38:51 from (209.214.64.41):
In Reply to: Re: MagMan...Please Read posted by MagMan on January 25, 2006 at 12:14:23:
Hey MagMan, a great guy by the name Gene Bender has been helping me with my '44 Farmall A. It has starting problems. I know that you know Gene, and anyone who has had any dealing with Gene knows he's a great guy always willing to help and a great wealth of knowledge. Gene and I have run out of ideas on what’s wrong with my tractor. It ran and started fine until I rebuilt the governor and steering gear assembly. It took me three weeks to rebuild as I only worked evenings on it. I made sure the two dots on the governor lined up with the gears on the timing. They are right on. I’m not getting any spark. I took the coil wire and held it next to the ground screw and cranked and got nothing. I cleaned the post on the coil and metal strip on the coil cover. I cleaned the connections on the coil wires. I dressed and re-set the points to .013. I sandblasted the spark plugs. Nothing really changed in the three weeks since it was cranking and running fine. Any ideas? Also, what is your web site name?
