Re: Farmall M tire weight
Posted by John A. on July 08, 2006 at 20:28:48 from (4.227.104.57):
In Reply to: Farmall M tire weight posted by Jerry Deimerly on July 08, 2006 at 19:39:01:
Jerry, Say you have + - 50 gal fluid in the tires, @ 8lb/gal= 400 lb in liquid ballast. Tire,tube,Rim will go about 150 lbs + - .
All in all you should be in 550 lb ballpark. A tractor w/ loader will make short work in moveing it around. Do not drop the tire for it will require a loader to get it back up. Two people should be able to handle rolling it around quit well.
Laater,
John A.
