Re: Farmall M tire weight
Posted by GordoSD on July 09, 2006 at 17:21:45 from (66.115.200.140):
In Reply to: Farmall M tire weight posted by Jerry Deimerly on July 08, 2006 at 19:39:01:
If you are going to restore those rims properly, you need to drain the fluid, remove the tires and tubes. See my post re "SMTA Rim Resto" a few pages down on off the archives.
And why do you want fluid in them anyway ?
Gordo
