Re: 6v to 12v on H question
Posted by farmallhal on July 09, 2006 at 18:39:02 from (64.24.35.17):
In Reply to: Re: 6v to 12v on H question posted by JSchill on July 09, 2006 at 18:23:17:
I saw on the forum a post of a year or so ago where a person in their same situation with a down loader had to move the tractor. The process, as I recall was to put the tractor in reverse and pull it backward with the belly pump engaged and in the lift position. Pulling the tractor would operate the belly pump by providing pressure to raise the bucket enough off the ground so it could then be pulled forward. I would think this would be better with the spark plugs removed. The belly pump would be working off the transmission to provide hydraulic pressure. Hope this is of help to you as well. Hal
