Re: Little Genius Plow question
Posted by Red Dave on April 10, 2009 at 12:12:00 from (98.235.15.235):
In Reply to: Little Genius Plow question posted by Nebraska Cowman on April 10, 2009 at 05:57:28:
Howard, I don't know for sure whether it will cause you a problem to take one bottom off, but I think you can do it if you change the plow hitch to put the center of draft between the remaining bottoms.
I know of more than one #8 plow that has had the original bottoms replaced with Super Chief bottoms. The frog of the Super Chief will bolt right up. As far as I know a Plow Chief frog will too. I've done it on my single bottom #8, works very well that way.
