Re: Farmall H clutch Fingers Question
Posted by Dave S. on July 09, 2006 at 20:04:43 from (204.95.118.130):
In Reply to: Farmall H clutch Fingers Question posted by farmallwayne on July 09, 2006 at 19:37:06:
The clutch plate and pressure plate will come out without splitting the tractor. These parts will have to be removed,hydraulic pump, clutch shaft, clutch release shaft, clutch release sleeve carrier and then the pressure plate and clutch plate. Everything comes out the bottom of the torque tube. Be carefull the pump is heavy.
