Re: 42 H won't start
Posted by rmthunder on July 09, 2006 at 20:05:39 from (4.225.5.59):
In Reply to: 42 H won't start posted by rmthunder on July 09, 2006 at 14:10:37:
To reply to the replys,
Dave BN, yes it was running fine last week, the air cleaner is free of obstuctions, I think it made one final POOF through the muffler before it died, I haven't checked the timimg yet, but hadn't thought about jumping time, THANKS
Gordo SD, I checked and adjusted the float tonight but ran short on time, and didn't try to start it as is was 10:30pm here and time to close up shop. The needle valve was cutting off the gas flow when I was testing it manually. I did lightly tap then needle just in case. Also, I do always shut the gas off. Thank you for your input.
Jossette, I did check the choke function, and it is working properly, Thank you for the advise.
I will let you now if the float adjustment works tomorrow, if not I'll look into the timing.
Thanks to you all, your time and input is very much appreciated.
Roger B. Near Cincinnati
