Re: Alternator overcharging
Posted by Bob M on July 10, 2006 at 04:39:09 from (151.190.254.108):
In Reply to: Alternator overcharging posted by CharleyFarmall on July 09, 2006 at 19:32:04:
Charlie - If the alternator terminals are labelled R and F it means it's an early Delco unit. These require an external regulator for it to work properly!
An internally regulated alternator the aux terminals are labelled "1" and "2". Also the internally regulated's aux terminal spades are in line (like this: - - ) vs the the older units have the aux terminals arranged in parallel ( | | )
Anyway you need to either wire up the correct regulator or else swap in an internally regulated alternator.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
