Re: Can second and third gear
Posted by old on July 10, 2006 at 09:37:06 from (4.245.3.216):
In Reply to: Can second and third gear posted by Delbert on July 10, 2006 at 07:51:19:
I have never seen a tooth welded back on that held up long if at all, you should replace that gear out you could/will end up takeing out more gears when the tooth/teeth brake off again
