Re: 504 Alternator Conversion Question
Posted by Gary in Mozarks on July 10, 2006 at 10:46:02 from (64.240.21.167):
In Reply to: 504 Alternator Conversion Question posted by Duane WI on July 10, 2006 at 10:09:51:
Sounds like you have a one wire alternater, which is internally excited. They use them alot on hot rods etc, because its simple to install, but the idiot light on the dash won't work with them. you need a voltage or amp gauge . IF you use an old Delco 10SI or 12SI they are a three wire alternater and you need a resistance in the curcit to make it work, so the dash light works fine for them. The confusing part is that the one wire alternaters still have the plug on the back edge of the case just like a three wire alternater (although the rebuilders ususally put a plug over it.
I usually have to go back and look at the diagram to hook up a three wire, and get it right, but the diagram is easy to find if you type alternater conversion diagram in your web browser. There is probably a diagram here somewhere on YT too.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
