Re: 504 Alternator Conversion Question
Posted by Duane WI on July 10, 2006 at 11:57:45 from (72.1.16.78):
In Reply to: Re: 504 Alternator Conversion Question posted by Gary In Mozarks on July 10, 2006 at 11:08:54:
I am pretty sure it is a 3 wire alternator. It is a diesel so the tractor will run with the key off. When the tractor is running and the key is on there is 14.5 volts on the battery. If the key is turned off the voltage drops to 13.6 volts on the battery. Thanks to all for the feedback. I think I will get a 10 ohm resistor installed the next chance I get and also put in a voltage meter. Again thanks for the help.
