Re: Super A loosing oil pressure??
Posted by old on July 10, 2006 at 16:44:26 from (4.245.13.154):
In Reply to: Super A loosing oil pressure?? posted by Nickc711 on July 10, 2006 at 16:13:14:
Well what I use is a stright weight oil like 40W or 50W in the summer depending on the tractor. I don't like or believe in the multi stuff since it never really gots as thick as 40W if its say a 20W-40 its still thinner then a 40W. As far as dieing at idle that could be an adjustment on the carb or carb problems. If the idle is set to low it will die on you
