Re: Super A loosing oil pressure??
Posted by Andrew Martin on July 10, 2006 at 17:08:39 from (64.219.39.195):
In Reply to: Super A loosing oil pressure?? posted by Nickc711 on July 10, 2006 at 16:13:14:
I believe in the multigrade stuff because I do believe the oil companies know how to make oil, and it does get as thick as single grade at temperature, you just can't believe how thin 40w is at 250 degrees.
20 psi is plenty. I have an A and C that drop to less than 5 psi when hot but they do OK. Oil pressure is just to replenish the oil film in the bearings, the film makes it's own pressure under load. That is why the idiot lights on cars are set so low.
The engine should idle down, the idle circuit is probably plugged.
