Timing a Farmall H
Posted by Elk Farmer on July 11, 2006 at 06:49:57 from (205.188.116.133):
I'm in the process of timing my H. Here is what I done so far. Please tell me where I'm going wrong.
Got the # 1 Piston on the compression stroke and the piston at top dead center.
The timing pointer is pointing at the first notch on the front pulley.
Turned the mag so the notches line up with the mag drive notches.
The roter is pointing to the #1 on the dis.cap.
I have one question. On the dis.cap there is a 1 stamped in the cap in-between two of the plug wire terminals, is #1 the top terminal going counterclock wise?
Thank You
Carl from Michigan
