Re: Saginaw 3pt ???
Posted by sde on July 12, 2006 at 03:38:06 from (69.179.4.153):
In Reply to: Re: Saginaw 3pt ??? posted by CNKS on July 11, 2006 at 17:20:52:
Does the Saginaw attach to the axle housing only, or do they use the mount holes in the side of the center housing? I had intended to copy the system that is on a coworkers M, but now I think I will try to keep my original hitch. My 400 has some 3/4 inch mount holes on each side of the housing. Can I use them for mounting a 3 point?
