Re: Cheep tricks
Posted by in-a-bind on July 13, 2006 at 00:12:47 from (170.93.140.8):
In Reply to: Cheep tricks posted by Baxter on July 12, 2006 at 17:38:52:
There are no CHEAP TRICKS when you are pulling.
Everyone does things a little different.
Everybody CHEATS some way or the other with the so called STOCK tractors.
If you are new to the pulling circut you better get ready to spend some money if you expect to compete with the others that have been at it for a while.
Before going too crazy, the first thing that you should do is ckeck to make sure that you are within the rules (if any apply), in case someone checks out your tractor, and the judges decide that they will NOT let you pull against their regular or favorite pullers.
