Re: Govonor for Super M
Posted by Brownie 45 on July 13, 2006 at 00:33:08 from (207.177.82.205):
In Reply to: Govonor for Super M posted by Matt Modlin on July 12, 2006 at 17:35:50:
Have you checked the air cleaner cup for buildup of dirt or other foreign material? Is there a restriction in the air intake system[ collapsed inner ply on the air hose to the carb? ] possibly? Check for leaks at the manifold to head gasket area with engine oil.Sounds like a fuel starvation problem, though. If it runs rough at all speeds, maybe the valve lash needs to be checked.
