Re: any spacers used when mounting a factory wide
Posted by JD Humm on July 13, 2006 at 03:18:12 from (70.249.161.190):
In Reply to: any spacers used when mounting a factory wide fron posted by Paul G. in Mn on July 12, 2006 at 18:22:53:
Those are common washers, believe it or not. We get them at work all the time for bolting elevator guide rail brackets to I beams plus other applications. We call them "hillsides" and we have had them in all sizes, from 3/8 up to 3/4 inch hole diameter, depending on what application we are using them for. I have handfuls of them out in my work van, left overs from jobs. They usually send us out way more than we need with each installation.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
