Re: any spacers used when mounting a factory wide
Posted by Dave Slater on July 13, 2006 at 06:04:53 from (205.188.116.133):
In Reply to: any spacers used when mounting a factory wide fron posted by Paul G. in Mn on July 12, 2006 at 18:22:53:
If you have early original wide front with tie rods out front.The steering arm bolted to vertical steering shaft with 3 bolts and no spacers. There was 2 different part numbers used on early ones.The washers other fellows are refering to go on inside of frame rails where rear support bolts up on some wide fronts.My mistake if steering arm is not the part ask about.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
