Re: IH 464D oil
Posted by El Toro on July 13, 2006 at 16:53:04 from (152.163.100.65):
In Reply to: IH 464D oil posted by Andy Whitehead on July 13, 2006 at 06:08:07:
I wouldn't mix kerosene with the engine oil. You can probably keep using your 30wt oil if you install a tank heater to prewarm the oil and engine. You can get one with a 1500 watt heater for about $40.00 from this company. Here's their phone number 1-877-292-0833. Hal
PS: If you click on Keyword and type in tank heaters for tractors will give you more choices.
