Re: any spacers used when mounting a factory wide
Posted by JD Humm on July 13, 2006 at 18:36:50 from (70.248.75.133):
In Reply to: Re: any spacers used when mounting a factory wide posted by K.B.-826 on July 12, 2006 at 18:51:27:
Will not stay tight and more apt to break, all the force is applied to one edge or corner of the hex bolt head. Those are not a special made part, any large fastner supply company should have them. We use them all the time at work.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
