Re: powersteering fix
Posted by Bob M on July 14, 2006 at 06:18:24 from (151.190.254.108):
In Reply to: powersteering fix posted by budaa on July 13, 2006 at 21:00:08:
Nice looking ‘ol 400! Judging from the shape of the tin, condition of the WFE, etc the tractor was well cared for. I've never messed with Behlen PS (all our tractors have Charlyn...). However the leakage on yours looks like worn input/output shaft seals as the others suggest. A few other comments/suggestions to the captions in your photo: With a one wire alternator simply tape off the unused auxiliary wires – the new alternator doesn’t need ‘em. And don’t worry about it burying the ammeter needle after startup – it’s just the alternator throwing a good charge into the battery. However as the battery reaches full charge the ammeter reading should taper off to just a few amps - like halfway to the first gage mark to the right of “0”. If you know a good welder you might have him try brazing a ¼-20 nut to the busted out spot on adjustable fan pulley flange right on the tractor. Then to lock the pulley adjustment stick a ¼-20 allen head set screw in the brazed-in nut and run the set screw down so it’s just snug (not tight!) in one of the hub grooves. Finally secure the set screw with a ¼-20 locknut. That ignition switch looks original. Replacement keys are readily available and cheap. Note the same key fits any IHC and Oliver tractor (and probably many other makes) of that era. The markings on the upper half of the tach serve as a “speedometer”. Simply look at the band for the gear you are currently in – speed is then indicated on that band by upper tach hand. The “hernia” around the valve stem on the rear tire can probably be repaired by brazing/welding. For a quick fix however you might try cleaning the area up thoroughly. Then if you find there’s enough good metal remaining around the valve stem opening, using JB Weld or similar to bond a flat washer to the rim with the valve stem sticking the hole in the washer. Not elegant, but it works - and you don’t need to demount the tire to do it! --- Nice photos BTW!!
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
