Re: Check compression on Farmall M
Posted by old on July 14, 2006 at 16:32:43 from (4.245.0.208):
In Reply to: Check compression on Farmall M posted by Don L C on July 14, 2006 at 16:03:42:
You might try putting about a 1/4 cup of tranny fluid in each cylinder and let it sit a couple days and then try starting it. The tranny fluid will loosen up the rings and boast the compression and may even fix the problem if its stuck rings.
