Re: 48 H goes missing and quits, HELP!
Posted by Hermit on July 14, 2006 at 17:39:03 from (69.21.48.33):
In Reply to: 48 H goes missing and quits, HELP! posted by TNFarmall on July 14, 2006 at 16:58:35:
Make sure you check the fuel cap vent is clear. Also when the engine starts missing, have you tried to keep it running by pulling out the choke? If the engine runs better with the choke pulled out then its a fuel problem. Otherwise, its probably a electrical.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
