Re: Check compression on Farmall M
Posted by Hayfarmer on July 14, 2006 at 20:58:47 from (66.243.249.207):
In Reply to: Check compression on Farmall M posted by Don L C on July 14, 2006 at 16:03:42:
two more things when checking compression, open throttle, pull coil wire so you don't have a spark that ignites the vapors comeing from the open cylinders.
