Re: Amp Gauge
Posted by Brownie 45 on July 15, 2006 at 14:17:57 from (207.177.82.186):
In Reply to: Amp Gauge posted by ryan from WI on July 15, 2006 at 10:05:30:
Might try using a fine stone in a drill press at high speed. Set the table to one side of the quill & put the meter face down on a shop rag which has been put on the table to dampen vibration. Very slowly grind off the crimp on the outside edge a little at a time. To reassemble, use clear silicone seal sparingly on the outside circumference where you ground the crimp earlier. This probably won't stand up to a major earthquake, but will probably last. Most of the modern gages have a plastic needle which tends to droop in the heat. If this is your problem, use care when bending the needle.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
